Pany 32PK1 Scart Prob
Discussion in 'General TV Discussions Forum' started by Russell Brown, Jul 1, 2001.
  1. Russell Brown
    Russell Brown
    Hi Team !
    I have just brought one of the above sets great pics and sound but...
    When I plug in the scart to AV1 no pics sound ok I tried this with my DVD and Digibox and VCR same result all OK on AV2. Called comets spoke to one of their resident experts ??? and was advised to turn the set off at the mains then leave it for about an hour then it would be fine I did this and it worked..
    My question is :
    WHY
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I'd suspect you kicked in some protection circuitry on the set either by clumsily ( no offence) inserting the scart (some of the pins are used for downloading firmware when hotwired) or some sort of mains fritz (unlikely as the AV2 input was OK)
    You are using RGB I take it?
    Great set by the way.
