Pansonic Prog setup
Discussion in 'Projectors, Screens & Video Processors' started by scollops, Dec 31, 2003.
  1. scollops
    scollops
    Just got a Panasonic Plasma 42 " TH42PA20B and the SCHT 900 home cinema kit - I was looking to set up progressive scan as all should be compatible.
    I have connected up using Component cables and enable progressive on the DVD although I am unable to alter or access the settings for it as per manual details - anyone point me in the right direction ??
    How did I tell if its working - you can press the progressive button on and off regardless dosent seem to do much either.
    :confused:
  2. outtathaway
    outtathaway
    Dec 2, 2003
    40
    2
    11
    huddersfield
    Progressive scan is only possible on NTSC on the SCHT900, its just a case of selecting Progressive output on the player and the P6 autodetects and switches to Progressive mode.
    If your SCHT900 is n't multiregion then finding Reg 2 NTSC discs can pose something of a problem.
  3. scollops
    scollops
    Cheers outtathaway - yeah noticed that eventually - looks like Ihave to upgrade me thinks then - new DVD and speaker setup - DOH !
