Pansonic interference
F
ferndown
I have just bought a Panasonic DMREH60D and I also subscribe to the NTL analogue cable channels and so have their set-top box connected through the RF aerial input. I have discovered a problem in that there is interference on some (not all) of the NTL channels, which takes the form of a jerky picture and white flashes about every few seconds
Has anyone else experienced this and how can I solve it. THanks for any help.
Maybe you need a better-quality RF flylead - I had an interference problem with a VCR, I replaced the supplied flylead with CT100 cable (CT125 I think is even better) and I also used metal coax plugs instead of the cheaper plastic ones.
What makes a 10/10 MOVIE?
Back
