Pansonic DMRES10 -RW Help
Discussion in 'Blu-ray & DVD Players & Recorders' started by marklfc77, Aug 29, 2005.
  1. marklfc77
    marklfc77
    Aug 29, 2005
    65
    Hi I'm newto the forum and I'm not up to speed with DVD Recorders I just bought the Panasonic DMRes10, what I would like to know is when you record in -RW and you have to finalize the disk so that it will play on other DVD players. I recorded a programme so that i could test the disk on my Sony DVD Player which says it could playback -rw disk which it did, I also have an older JVC and in the manual is says it couldn't playback -rw I put the disk in to check and It seemed to work ok? I must state that the -rw disk was recorded in SP mode and not LP or EP mode is this the reason why it worked or am I missing something like when you finalize the disk it converts to DVD-RW(video mode) is this the same format as pre-recorded DVD discs?
    Thanks for the help
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
