Pansonic DMR-EX75EB error code 81
HSmith
Please does anyone know what this error code means when this dvd recorder boots up. Thanks
bonzobanana
check out my service manual thread above. It lists error codes for the ex77/87 which are probably the same for the earlier ex75.
Gavtech
Administrator
Welcome to the forum.
These are error codes generated by the main microprocessor which are tripped by corruption, preventing it's operation and which requires the processor to be reset.
The codes do not actually point to a specific cause because the corruption error potentially has a great many possible causes.
It does not point to any specific fault as such.
A U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter' ... which does not tell you anything useful at all.
Corruption can arise for many different reasons .. and is not surprising in a box that has an aerial feeding endless streams of complex data into it, has a mains connection with interference on it, has two internal data storage and retrieval systems, either of which can be problematic... and sits permanently bathed in electrical and radio frequency fields of varying intensity.
In practice, all one can do is follow good practices:
Don't stack gear - or give it plenty ventilation if you do.
Ensure good clean mains supplies.
Ensure a properly installed aerial system with sound connectors and adequate screening.... etc.
If you get this error immediately at boot up, and cannot get beyond it, then the unit may have a problem.
HSmith
Thanks for the replys, I guess I have a problem on the unit as it goes thro' its routine upto Hello and showing the HDD icon before entering repeatedly the U81 error message
LG G3 MLA OLED Evo Best Picture Settings - works for ALL 2023 LG OLEDs
Back
