Panoramic printing?
Discussion in 'Photography Forums' started by witters, Sep 10, 2004.
  1. witters
    witters
    Jul 13, 2000
    12,745
    Yorkshire
    +302
    Does anyone know of a printing outlet online that goes bigger than 30" x 10" for panoramic prints please?
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
  3. witters
    witters
    Jul 13, 2000
    12,745
    Yorkshire
    +302
    Looks good - have you actually used them?
  4. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Not yet - can't access the site from work to be honest but I'm a member of a couple of photography forums and ezprints do come well recommended.
    Is it a digital print you're doing, what resolution have you got?
    For UK prints the best I've found is 30" accross.
    www.fotoinside.co.uk define one side of the print (the short side) so they may be able to do and *anything* by 8" print but I don't know for certain.
  5. witters
    witters
    Jul 13, 2000
    12,745
    Yorkshire
    +302
    Yes it's a digital print. Size I would like is 48 x 12 at 250dpi. Size of file is 74meg.
  6. witters
    witters
    Jul 13, 2000
    12,745
    Yorkshire
    +302
    It looks as though it will be quite expensive after carriage etc.
  7. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
  8. witters
    witters
    Jul 13, 2000
    12,745
    Yorkshire
    +302
    Thanks.
  9. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    One last one - another US one and no mention of overseas shipping but may be worth contacting them
    http://www.perfectposters.com
    Let me know how you get on as I'll probably have a few I want to print at some point!!
  10. witters
    witters
    Jul 13, 2000
    12,745
    Yorkshire
    +302
    Thanks Andrew I will. Your efforts are much appreciated. :smashin:
  11. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    No worries - I'd try some myself but I don't have any panorama's I'm completely happy with at the moment to put on my wall - will hopefully get a couple in Menorca next week !!
  12. Mike Hall
    Mike Hall
    I have used a company called fotoserve.com for printing panoramics. They only have smaller panoramic sizes mentioned in the price list, but they do print 24xany-length prints upon request, so they'd be able to print your panoramics at any size you want. I have mentioned this company on other forums, and used them many times.
  13. witters
    witters
    Jul 13, 2000
    12,745
    Yorkshire
    +302
    Mike,
    I assume you mean 24" high? So in theory I could have 60 x 24? Wow - that sounds great. Better get a mortgage for the frame though :D
  14. SanPedro
    SanPedro
    Jan 11, 2001
    4,536
    +521
    If you want really big prints try these people;
    http://www.imagegroupuk.com/
    They did a lot of the huge images on the side of buildings at the Commonwealth Games in Manchester and their prices are pretty reasonable too. They can print onto pretty much any sort of material so could do a large print straight onto a piece of 10mm white PVC board that you can mount directly onto your wall.
    Chris
  15. panoprint
    panoprint
    I do panoramic printing, but at the moment i'm limited to 10" height (210mm) , but 10m length. The paper becomes an extortionate expense at sizes above that and is so seldom used that I don't buy it.
    Does the image have to be 12" ?
    anyway, take a look at my site, its www.panoprint.com if you'd like to e-mail me the pic to see what size i can get it to, then please feel free. It doesnt cost anything just to check it out :)
