Panny6 and Avia DVD help needed!
Discussion in 'Plasma TVs Forum' started by terence8888, May 26, 2004.
  1. terence8888
    terence8888
    Jan 6, 2004
    146
    +4
    Hello,
    Finally got a Avia dvd to calibrate my panny 6. However, on the screen to setup contrast/white level, I cannot see the moving white bar at the bottom half of the screen whatever value I set the plasma to (the min/max is -30/30). Has anyone got the same problem? Dvd is DV88+.
    Thanks in advance.
  2. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    Not too sure of whats causing the problem and I'm not familiar with the 88+, but just check that your dvd player is outputting black at 0IRE and not 7.5IRE, I'm assuming your using a component connection?
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,970
    I would use Cinema setting on plasma but this is probably not the issue.
    Go in to ADVANCED settings in the picture menu of the plasma. Go to the INPUT SIGNAL LEVEL setting near top. With the pattern on and the moving bars invisible start turning input level down and marvel as they miraculously re-appear ( I hope).
    Let me know if this works for you.
    Gordon
  4. terence8888
    terence8888
    Jan 6, 2004
    146
    +4
    Thanks very much Gordan. This works!
    Is it possible to calibrate for my pioneer freeview box too I wonder?
  5. jmack
    jmack
    gordon can this be done on a toshiba 42wp16(panny 4 series clone) ;)
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,970
    No, I think only the 6 series Panasonics and their clones will have this menu adjustment. Glad it worked. Now I really must stop giving away my secrets......
    Gordon
