Panny5 setup problem - please HELP !!
Discussion in 'Plasma TVs Forum' started by frogfriendly, Mar 12, 2003.
  1. frogfriendly
    frogfriendly
    After a long time learning from this forum I have today finally entered the world of plasma screens and have a shiny TH-37PW5B in my front room.
    It's been delivered with an RCA terminal board and Scart to RCA cable which has 4 outputs R, G, B and a Black connector.
    I'm having extreem dificulty getting it going. Does anybody know if it's correct to connect the Scart to a Telewest cable TV box, set to RGB output and then connect the R,G,B and then Black connector to the HD ? Do I need a 5 ouptut cable with R,G,B,HD and VD instead?
    At the moment I get no signal but occasionally the picture flickers in very instable and the disapears.
    Thanks:lesson:
  2. jmack
    jmack
    hi i dont use one of these leads so might be totally off here,
    i think i read that the extra lead is for sync connect it to the composite imput , then in the setup menu change to sync on video
    or something like that,
    i am proberly wrong but i bit of testing and i`m sure u will get it going
    you could try the search button
  3. jmack
    jmack
    i think i was nearly right
    search for this thread Scart - RGB+CS questions. someone puts it better than me in there
    hope it helps
    been reading old posts about this and just relised this method takes up alot of imputs just for 1 thing,
    surely better to buy a converter leaves you more options then
  4. frogfriendly
    frogfriendly
    Thanks Jmac,
    That worked a treat ! I can now start enjoying :)
  5. jmack
    jmack
    thats ok advice is half price for this week only :D :D
