Panny WD6 - issues with prog scan
Discussion in 'Plasma TVs' started by DTech, Nov 26, 2003.
  1. DTech
    DTech
    Nov 26, 2003
    52
    11
    Buckinghamshire
    +5
    New to the forum as a member but been browsing for some time. Tweaking my new Panny WD6 last night and noticed what could only be descibed as a green shimmer across the whole image during playback of DVD via component (pal progressive scan) - does anyone have an answer for this before I start pulling out cables - source is an Arcam 88 plus.
  2. philipb
    philipb
    Mar 6, 2002
    1,986
    63
    Swindon
    +132
    Try the obvious ones first - is the red cable fuly plugged in at either end?
  3. jmack
    jmack
    check for latest fireware on the arcam dv88+ and as said above check all cables are in
  4. DTech
    DTech
    Nov 26, 2003
    52
    11
    Buckinghamshire
    +5
    Not the cables and unlikly to be the panel - no problems when fed through scart - must be either the board or the 88 plus - my moneys on the 88 plus - i'm running on the following 3.0.0 LT76/02/ff = will phone Arcam tomorrow
  5. jmack
    jmack
    sounds like a firmware upgrade is needed the newest one is 4.12.0
    let us know how u get on.
    if you are able to burn your own cd for udgrade drop a pm to robocop i`m sure he will email you the files
  6. DTech
    DTech
    Nov 26, 2003
    52
    11
    Buckinghamshire
    +5
    Update - avoid the picture adjustment options at all cost - I had it set to movies and this was what was causing the picture problems - wasn't apparent with scart but via component it looked horrible - now run it on normal but have tweaked down the colour, contrast and brightness settings - looks great.
