Panny VGA Cable question
Discussion in 'Cables & Switches' started by stuartg, Feb 28, 2005.
  1. stuartg
    stuartg
    Feb 20, 2005
    After purchasing the 42" deal from av-sales, the mediabox is supplied with a 3m VGA cable. I believe I need a 4m cable, therefore what cable would you all recommend I purchase. The Panny is only equipped with a vga connector (as per the deal).
    I would ideally like a good quality cable, and I understand that shielding etc is a must...
    PLease help me with your suggestions, as this cable will be run in the wall, so getting it right first time is a must.
