Hi guys,
Im in for a new 60 incher, im between the UT50 Panasonic and the Samsung E6500, which should i go for?.
Black levels are important to me, im currently using a UT30 50", does the E6500 compare to it?. I do a lot of pc gaming and IR is an issue with the Panny i heard, unlike the Samsung, but the real deal breaker in my case is the black levels, which is better i go for, or if at least the Sammy compares to a UT30 in that area than i will give the Sammy some serious consideration, cheers.
