kevshed
Hi guys... appreciate some views here plz..
I currently own a 42PW3 panny panel, which ive had for a year... love it to bits, very happy with it.
I have a dillema, in that i use for FMJ DV27 as primary viewing source, any mainly use R1 material, so make best use of the 480p progressive scan.
However, i now want to make use of the Pal-Progressive (sshhh dont tell anyone... please no flaming on is/isnt possible p), but the W3 unfortunatly doesnt support 576p.
Therefore considering upgrading the screen to a newer model to accomodate my requirements, (i have a buyer lined up for my W3).
Question is:
Is it worth the upgrade... W3 -> W4/W5... or Is it possible to fit a W4/W5 video processing board into my W3, if so any idea of cost.
Failing that, is the pansonic still the king of displays.. it was when i bought mine, but would consider pioneer maybe.
Also curious on whether the DVI option is worth taking.
Views appreciated.
Kev
Question is:
Views appreciated.
Kev
