buzlightyear
When viewing DVD's through my Denon 3800 using a QED Squart RGB lead to my Panny PL1 (RGB input) the reds are red (and i mean red), they over power everything (brake lights for example) its not natural like the other colours. Normal tv (cable) is fine, this daisy chains through the denon. As far as i know svideo is ok. I will double check tonight. Ive also noticed a slight bleeding when using my Import GameCube on the reds, but this is going through svideo into a Denon 3802, into a non RGB connection. My PS2 which is also going through the amp is fine.
Are the reds turned up to high in the service menu? if so anybody got any good settings?
Buzz
(Ive got a working Denon 3800 MR, PAL Prg,Chroma free player...what more could a boy want)
Buzz
