Panny TX-36PG50 audio line outputs
Discussion in 'General TV Discussions Forum' started by MikolaH, Mar 29, 2001.
  1. MikolaH
    MikolaH
    How do I make the audio line outputs to have fixed signal level?
    Now I have to go to the surround setup to put the internal speakers off first, then turn up the volume to match the input sensitivity of my external audio preamp/prosessor. And every time I forget to put the internal speakers on again, the kids get no sound from the TV-set.
    Is there any service menu for sound and/or connections?
    Regards,
    Hannu
  2. encaser
    encaser
    Mar 15, 2001
    3,593
    Suffolk/Essex
    +1,207
    can't change audio output to fixed level, service menu only for geo etc
