Panny TX-32pl10
Discussion in 'General TV Discussions Forum' started by Phil Durkin, Mar 28, 2002.
  1. Phil Durkin
    Phil Durkin
    Can anyone who currently owns this TV give me there honest opinion on the picture quality, i will be mainly using it via a Pioneer DV 545 player, the sound is unimportant. Do you have any other suggestions for a similar priced Nicam only TV (£1000), remember picure quality is the main issue. kind Regards..
  2. Guest
    I have this Panny and I have to say that I am very disappointed with it's overall performance. I owned 2 Panny 4:3 sets and they were brilliant.........I initially went for a Philips 32"6515 set but had to return 2 faulty sets....so I went for the PL10 instead.....I am on my 2nd one because the first had a faulty RGB socket.
    My main complaint about this set is that the digital processing is very noticeable with strange artifacts visible when panning accross the screen. I had expected to see a far smoother picture with the 100Hz but instead I actually see more flicker than I did with a 50 Hz set........I think I should have gone for the PL1 instead.
    I looked at an awful lot of widescreen sets when I was trying to choose the model to buy and I think the best picture I saw was on a 50Hz Sony but I can't remember the model number.
    Gordon
