Panny TX-32PD30 Anyone know which Scan Modes are best?
Discussion in 'General TV Discussions Forum' started by dazgwinn, Oct 21, 2004.
  1. dazgwinn
    dazgwinn
    Apr 6, 2001
    324
    43
    u.k
    +101
    I'm just going thru all the scan modes availible, anyone know which ones are best?Which ones are Acuity?Are they all Acuity?What's the 75/833i?Panasonic make great t.v's but hopeless operating instructions.Cheers Darryl.
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    The 75/833i is the Acuity bit.
    The other options are for those occasions when the Acuity processing makes matters worse (eg snooker!).
    If you do a search on this Forum for "PD30 Scan Modes" (16/05/04) you'll see my full explanation.
    Hope this helps. :)
  3. dazgwinn
    dazgwinn
    Apr 6, 2001
    324
    43
    u.k
    +101
    Cheers TG
