Panny to PC help
Discussion in 'Projectors, Screens & Video Processors' started by MrCoopz, Jul 6, 2002.
  1. MrCoopz
    MrCoopz
    Jun 28, 2002
    712
    28
    +25
    i have connected my PC via ProV to my projector but the quality is pretty poor.
    does anyone have any ideas to make it better??
  2. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Mmmmm have you got the settings right ie/what resoution is your pc on and also the Pro v?
    I must have been lucky mine worked fine 1st time .Try playing around with both the PC resolution and the pro v resolution, see what happens
  3. MrCoopz
    MrCoopz
    Jun 28, 2002
    712
    28
    +25
    when i have the PC on the screen i cant change the resolution
    how do u change it?
  4. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Change the Pro v with the left hand bottom switch.. it pauses for a moment
  5. Guest
    Put the PROV on XGA resolution, should give the best results. I presume you're putting the PC through the PRO-V because you've got other things connected through that, just the best connection would be direct obviously and on 856 x 480 resolution
    Andy
  6. MrCoopz
    MrCoopz
    Jun 28, 2002
    712
    28
    +25
    Walter when im in PC mode only 2 buttons on the ProV work. Source and TV/PC
    The Scan button didnt work
  7. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Hi Mr coopes,
    The button marked XGA/VGA should work...mine does although it pauses for a moment give it a chance just press it once and wait a sec. My pc is set at 1024x768 .I havent tried adjusting that yet, I`ve tried the Pro v on all settings I`m not sure which I prefer. I think you`ve got to be good to see any major improvements. It`s basically great all round IMO. The pic from my PC is brill I`m still playinmg around to see if I can better it but to be honest I`m really pleased with the pic It`s really clear.
