Panny TH42PWD7B- Thoughts please.
Discussion in 'Plasma TVs Forum' started by 69COU, Sep 10, 2005.
  1. 69COU
    69COU
    Feb 8, 2004
    816
    +75
    This is on special at Ritcher Sounds for £999.95 under a grand
    conditions say must pay 99 for panel protection and i suppose about 130 for input board and similar for walkl bracket.
    Sounds like pretty good value though. Any thoughts or is this nor old technology as far as Plasmas. Want to get best out of SKY HD when launched.
    Cheers :eek:
  2. njr
    njr
    Aug 23, 2002
    115
    16
    Berkshire
    Its not HD compatible. You will have to go for a PV500 or a PHD8 when it is available.
  3. av2diefor
    av2diefor
    It will be HD compatible and will show a great pq, its not HD ready but if you sit any distance from it you wont know.
  4. njr
    njr
    Aug 23, 2002
    115
    16
    Berkshire
    I suppose so, if you want to buy a scaler and frame rate convert. Why not just buy a HD ready screen though?
    The PWD7 is only a standard definition screen in any case so if the OP wants to get the best out of sky HD, then it would not seem to be the best choice.
  5. av2diefor
    av2diefor
    Well its two opposite ends of the scale.
    A plasma for £999 or a setup costing £3000+ to get the best out of Sky HD.
    £999 will get you up and running give or take a couple of hundred, or you could spend £7000 on a Fuji panel, scaler etc.
    Its all down to how much you want to spend.
