Quantcast
Panny TH42PWD5UY
C
cujimmy
Does anyone know if this unit accepts prog scan signal? I am in the US and have DVD recorder that has prog scan output and wondered if I can connect straight in to the component input on the panny. I also see that this unit is not HDTV so would you need a set top box or will it still receive HDTV broadcasts but not in as good a quality. The specs seem misleading. Cheers!
NeilMcRae
Yes it accepts progressive scan. For HDTV yes you'd need an HDTV settop box.
Neil.
