panny th42pw7bx
Discussion in 'Plasma TVs Forum' started by JIMMY, Feb 28, 2005.
  1. JIMMY
    JIMMY
    hi bought a panny th42pw7bx from av sales
    happy with plasma but think picture is a bit soft when useing
    media box i
    ve got dvd player with component
    sky + with rgb
    ps2/ gamecube rgb
    laser disc
    so looking how 2 connect up what boards would i need
    getting confused with all these boards
    i like the look of this Quintro+ RGB Scart Switch Box
    could i put every thing in 2 this then connect via a card in 2 panny
    be gentle please as i dont have a scooby
    thanks jim :lease:
  2. zest
    zest
    Jan 24, 2005
    147
    16
    kenilworth warwickshire
    i think the media box tuner card disables the other slots ie vga, best way would be to not use media box and use quintro and js rgb >vga converter or quintro and scart board. might be totally wrong though!! anyone else??
  3. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    JIMMY
    What do you do for sound.............have you got an av amp you could route everthing through....................and flog the tuner.
    Cheers,Tam
  4. JIMMY
    JIMMY
    dont mind if i lose the tuner would miss teletext but not 2 worry
    so ive no cards my amp is a panasonic sa-ht870 im sure
    i cant put anything through it
    so can any one help
    looking for best conections for my stuff
    sky + with rgb
    ps2/ gamecube rgb
    laser disc
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    best order a dual slot board for DVD and laser disc and a JS RGB>VGA for the Sky and consoles....
  6. zest
    zest
    Jan 24, 2005
    147
    16
    best method js rgb>vga and quintro, use a component board for dvd.
  7. zest
    zest
    Jan 24, 2005
    147
    16
    hornydragon, how do you connect several items into a rgb>vga box?? do you need scart switcher?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  9. JIMMY
    JIMMY
    hi horny dragon
    just 2 make sure im getting this right (want 2 make sure )
    add a bnc component duel slot board £96 from avsales
    for the dvd and laser disc (this will give me best quality)
    js converter 2 vga £ 126 at av sales
    (can only see 1 scart would i have 2 unplug sky 2 put consoles in)
    would consell sky go in 2 js converter then i would ned a vga cable and use vga thats already on my panny th42pw7bx
    cheers jim :confused: :confused:
    9
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    se post above for how to connect sky and console to JS box, I would run console into switch, switch into Sky VCR socket and Sky TV socket into the JS box and then onto plasma on built in VGA input
  11. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    or.......3 scarts from sky and consoles to switcher suggested by HD, then scart from switcher to jsb box..................vga cable from jsb box to plasma.
    cheers,tam
  12. JIMMY
    JIMMY
    thanks lads ordered composite board and js rgb 2 vga box
    jim
