Panny th42pw6 or Tosh 42pw37
Discussion in 'Plasma TVs' started by dfield4, Oct 19, 2004.
  1. dfield4
    dfield4
    Thinking of buying Panny TH42pw6 or Tosh 42pw37, are they the same plasma display rebadged.
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    YEs they are. IIRC Toshiba has a two year warranty instead of one, and the Toshiba always comes equipped with Scart, Component and SVHS/CVBS boards.
  3. markevo
    markevo
    Aug 19, 2004
    32
    liverpool
    so does that mean that its a better buy than the panny ????
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    depends on the price panny with boards and warranty gonna cost you £2150 ish from AV-sales....... So if Toshiba is significantly less it may be a better buy. However if you wanted DVi input, and no others with tosh you get panel with all slots full and have to take one board out to put DVi board (that costs you extra) in...... depends on price of Tosh.....and what you want to connect
  5. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    d'oh horny beat me to it! only better if same price and you don't intend to upgrade to DVI.
  6. markevo
    markevo
    Aug 19, 2004
    32
    liverpool
    is it worth having the dvi option if i dont intend usung it at present ?
  7. dfield4
    dfield4
    Thanks for info. Panny costs £1678 with no boards and Toshiba costs £1799 from Richer Sounds which do you recommend buying.
