panny th42pe30b - help! 480i/p, 720 etc
Discussion in 'Plasma TVs' started by plasmaman77, Jan 19, 2005.
  1. plasmaman77
    plasmaman77
    Jan 9, 2005
    28
    Does the panny th42pe30b support 480p? obviously is supports 480i. does anyone know what others it supports.
    I've spent the last hour searching with no lick!!
    thanks in advance
    scott
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    480i/p, 576i/p and 1080i via component (same for VGA +perhaps another couple)
  3. plasmaman77
    plasmaman77
    Jan 9, 2005
    28
    thanks, also what happens if I connect a source 480i signal - will the tv automatically convert this to progressive scanning or do you need to choose to do this? cheers
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    The Viera is a progressive display device, it will convert (de-interlace & scale to native res of 852x480) all supported interlaced signals into progressive before displaying them.
    S.
