Panny TH42PDW6 and PC Connections
Discussion in 'Plasma TVs Forum' started by shaithis, Jul 18, 2005.
  1. shaithis
    shaithis
    Feb 25, 2005
    1,644
    The Last Aerie
    +31
    It seems when I connect a PC to my Panny, either by VGA or DVI, it shows an a rather weird artifact...
    Basically, there is a 1-2cm wide area down the left side of the screen that looks like a graphics corruption.....this only happens with a PC connected.
    If I go into the display properties there is a section for "flat panels" - 1 of the options in there lets you toggle between "Adapter scaling" and "Monitor scaling" - toggling this option makes it go away until you reboot.....
    Anyone know of a setting on the screen that can get rid of this?
