panny th42pa20 advice please
Discussion in 'Plasma TVs Forum' started by chriswynn, Jan 20, 2004.
  1. chriswynn
    chriswynn
    today i am getting to swap my c**p phillips 42"plasma for the panny th42pa20 could someone out there back my decision that i have made the right choice
  2. daveb975
    daveb975
    Oct 25, 2002
    4,320
    103
    London
    +368
    I have Panny 6 which is supposed to be similar internally to the PA20, and have been very pleased with it.
    Others on the forum recommend the Hitachi's, but I have recently seen them and don't think that they match the Panny. Probably worth demoing both if you can.
    The only plasma I would prefer to the Panny is the Pioneer 434, which is a lot more cash, and IMO only a slight improvement in PQ.
    Good luck!
  3. ChrisN
    ChrisN
    Oct 21, 2003
    742
    28
    +47
    I have a 42PA20 and am very pleased with it.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    If you want an analogue TV it's one of the best, though these things are a matter of taste!
  5. chriswynn
    chriswynn
    is the pw6 better
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    PW6 and PA20 are same panel, PA20 has video drive from PD30 range Speakers, scarts etc a proper telly, very nice unit. PW6 is a screen that you can connect to via scart, YUV etc
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    If you already have a sound system, and freeview works where you live, then the PW6 route is cheaper and some think better, but not so easy to connect to all your components. Nothing wrong with the PA20 though, speakers no better than any other TV, and analogue TV not too good on plasmas IMHO, otherwise, good toy.
