Panny TH37PW7 setup help for newbie plz
Discussion in 'Plasma TVs Forum' started by johnbhoy, May 5, 2005.
  1. johnbhoy
    johnbhoy
    here we go guys 1st post
    after reading thro many many posts on here i have decided to go for the
    TH37PW7
    Vivanco SBX-95 SE
    and scart board
    as i am already over budget what speakers would you guys recommend and or anything else i need
    thx for looking
    john
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Do you need an amplifier as well? or are you using the built in amplifier of the plasma? Are you wanting surround sound? What sort of budget are you restricted to?
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    What leigh is telling you there is that with the scart board in particular, you can connect almost any hi fi speakers to the thing, spring clip terminals, and get not too bad stereo out of it. A pair of eltaxes from Richers would do the job for £40 or something, save money now, get decent surround later? Surround sound will be from about £200 to do it properly, Pioneer VSX amp and a 5.1 pack is logical with the scart board, it switches 3 x RGB scart.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  5. fatherted
    fatherted
    Mar 6, 2005
    87
    Hampshire
    Don't forget you will need a Desk Stand (about £120) or Wall mount
    If using a Desk stand, then that will need something to sit on also.
    And some decent scart leads to connect every thing into your Vivanco (say £20-£40 each)
    PS - instead of the scart input board, has anyone tried the JS Scart - VGA box from the Vivanco into the VGA port of the Panny.
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    Fatherted, not with that particular one but I did have sky and ps2 going via another vivanco scart switcher to the js rgb to vga....worked perfectly
  7. johnbhoy
    johnbhoy
    ok here's the final deal, post replies fast pls as my mouse is hovering over the "buy now" button lol
    TH37PW7
    Vivanco SBX-95 SE
    and scart board
    rs wall bracket
    digitheatre DTS [my old system i was gonna bin]
  8. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    personally would go for the js rgb to vga instead of the scart board....the scart board is fine (nowhere near as bad as I thought it would be after reading posts here)..but the JS is better
  9. johnbhoy
    johnbhoy
    would that be compatible with the Vivanco
  10. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i used it with a different vivanco scart box and it worked fine
  11. johnbhoy
    johnbhoy
    this is the vivanco i am getting, so i hook output scart to JST RGB to Component Converter then how do i hook up to plasma [sorry bout the nebie Q's m8]
    [​IMG]
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you need tocheck that the inputs/output are RGB compatible, some cheap scart swicthers arent fully wired internally and dont support RGB i know the B-Tech Quattro and Quintro dont support RGB on all inputs. the Holden and Joytech do IIRC
  13. johnbhoy
    johnbhoy
    all vivanco in/out scarts are rgb m8
  14. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    the js rgb to vga needs a vga to vga cable form the js to teh vga input on the plasma. the vga is standard on panny and means you don't need the scart board...js box is about £120....but doesn't come with vga cable......i've tried £40 van damme vga cable and normal pc qulaity vga cable.......don't see any difference so no need to spend a fortune on one
  15. johnbhoy
    johnbhoy
    nice 1 mep thx for looking in and adding to my viewing quality at no extra cost ;)
    star man cheers
  16. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    even my cheap vivanco (about £35 from superfi) was rgb on all outputs....they are pretty good for teh money
  17. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    no worries mate
  18. johnbhoy
    johnbhoy
  19. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
  20. johnbhoy
    johnbhoy
    final setup [i hope lol]
    TH37PW7
    Vivanco SBX-95 SE
    JS Technology RGB to VGA Converter
    rs wall bracket
    digitheatre DTS
    will this do y/n
  21. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    looks good to me mate
