Panny Th37pe50 (hdtv)
Discussion in 'Plasma TVs' started by chief barker, Sep 10, 2005.
  1. chief barker
    chief barker
    Mar 26, 2005
    1,553
    +236
    Hi fellas,
    I have just ordered this plasma and I am wondering (well... more worried) that when HDTV comes into effect will my t.v still work with this type of broadcast.
    I am curently using ntl.
    Thanks in advance.
  2. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +15
    its not hd ready if thats what youre asking. it will display it but not at the HD resolutions. you need the 37pv500 for HD
  3. milkmanchris
    milkmanchris
    May 24, 2005
    898
    North Yorkshire
    +82
    But will the pq better than that of SD if you watch it through component?
    I have the 42" version of the same set.
  4. chief barker
    chief barker
    Mar 26, 2005
    1,553
    +236
    WOW. :smashin:
    Thanks for your quick reply, all i was worried about was that when HDTV comes into effect my new screen would not be compatible, and would not be able to display anything.
  5. chief barker
    chief barker
    Mar 26, 2005
    1,553
    +236
    Sorry I am new to this, What are you saying exactly? pq, sd?
  6. ukdan
    ukdan
    Feb 16, 2005
    1,124
    swindon
    +84
    pq=picture quality , sd=standard definition(pal) hd=high definition
  7. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +15
    it will display a slightly better picture but it will not display High Definition Pictures, since its not compatible, so very little point in worrying about HD.
  8. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    High Definition programmes will still look better on SD screens than DVD. But they'll look even better on HD screens, though not if you're far away.
  9. Steve_Whelan
    Steve_Whelan
    Sep 22, 2004
    117
    +3
    The Main problem with the PE50 is that it does not have a HDMI or VGA port, the initial trails of SKY HD and most likely BLUE-RAY and HD-DVD will allow a analogue conection via component, after the trials, most HD material will us HDCP encription which requires a HDMI port or a off borad decripter via VGA (possibly illegal), as the PE50 has neither HDMI or VGA this may cause problems long term.
