Panny TH37PE30B Cabinet Question
Discussion in 'Plasma TVs Forum' started by elliot_01, Nov 9, 2004.
  1. elliot_01
    elliot_01
    Nov 8, 2004
    60
    West Midlands
    Hi readers,
    I'm seriously considering buying one of these plasmas, within the next 2 months, so would appreciate if anyone could answer a question for me.
    All my current seperates (Sky box, DVD player etc) are housed on their own systems rack/shelving unit, so all I have under my current widescreen CRT is my Mission centre speaker (quite bulky). I doubt it would fit in between or below the glass shelves on the Viera's cabinet, unless the glass shelves are removable? I would imagine they, but I just wanted to be absolutely certain.
    Can anyone advise please?
    Thanks! :thumbsup:
    Elliot
  2. kriswood5
    kriswood5
    The shelves are removable as the cabinet comes flat packed and requires to be built. You could opt to not put both shelves in or you could also opt to place the shelves at a different height to the standard option as they were a few holes in the stand where the shelves could be fitted.
  3. elliot_01
    elliot_01
    Nov 8, 2004
    60
    West Midlands
    That's great, thanks! :)
