Panny TH37PE30 with SC-DM3 all in one
Discussion in 'Plasma TVs Forum' started by dew, Feb 8, 2005.
  1. dew
    dew
    Feb 5, 2005
    70
    Hiya,
    Recently purchased Panny 37" alongwith stand from JL, Brent cross for £1994 5 yrs free warranty :clap: Based on all the treads have reduced the contrast to null , picture mode to 'Normal' and color balance to quite low. Normal recommendation is to keep it the same for initial 200hrs. Is that correct?
    Also, I have panny SC-DM3 home cinema which I have connected with video cable. :rolleyes: and NTL cable which is connected via scart. It would be good if some one can letme know whether this is the best way to connect.
    :offtopic: Have heard lot of praise for Denon 500 home cinema. Was wondering if it's worth buying that or going the component way.
    Cheers, :rolleyes:
