panny TH-42PWD6, progressive scan?
Discussion in 'Plasma TVs Forum' started by spook, Jun 12, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Hi all, can anyone tell me does the panny TH-42PWD6 support progressive scan data if I install a component input module?
    I intend to use a panny DMR-E55 prog scan DVD player/recorder with component out.
    cheers spook
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    Spook
    You can send Interlaced or Progressive YUV to a PWD6 via the HD15 VGA socket or a TY-42TM6YB or TY-42TM6AB board.
    If you send the display Interlaced YUV you can use the Cinema mode to improve PAL and NTSC source material that was originated on film and if you send the Display a Progressive signal you'll get to see what the processor in your source device is up to.
    Best regards
    Joe
