Panny TH-42PW7B & TH42PW7
Discussion in 'Plasma TVs Forum' started by Bobby_Dazzler, Feb 21, 2005.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi all
    I guess u all know the question already!
    Whats the diff?
    http://www.digitaldirectuk.com/products_moreinfo3/index.asp?product_id=6352
    or the pw7 on digital-point.co.uk (c/w scart board)
    same price but the digital direct don't mention that it comes with a scart board. However it is a TH42pw7 "B"
    what would u guys go for?
    the other question is... is the PW7 ok with a js converter (rgb to vga)??????
    regards
    Bobby
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    i suspect digitaldirect doesn't come with any board other than vga which is standard on all. Have heard that scart board is not too impressive anyway.....component excellent though as is the vga using the js converter.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    PW7 is consumer model PWD7 is commercial (PWD slightly higher spec) both work with JS RGB>VGA box and both can use scart board/media box/infact all 7 series input boards.
