Panny TH-42PHD8EK, cannot enter to service menu
O
okkraj
Hello again, as the topic tells plasma has been bought from Germany and here is one happy person in Finland:).
I found several topics about service menu itself and instructions how to get into it. But I haven't found any topics about problems to getting into service menu so that's why this post.
Instructions tells that "Keep volume (-) button pressed and then press status-button (button with screen icon and "+"-sign inside the screen)3 times and service menu appears. Nothing happens in my display if I do this? Volume has been 0 - between - full when I have started the pressing of status-button (3 separate tries). In my remote control the status-button is above the setup-button as in instructions.
Here is one link for an instructions: http://www.bruzzi.ws/plasma-faq/showthread.php?t=23
All sites I have found (including this forums) has UK (USA) model as an example, is there something different in instruction in EK (european) model?
I would like to check if 100 hours milestone has been accomplished (I want to tune up the colors etc:).)
teosesa
Hi, I've the european model: TH-50PHD8EK and there's no difference in the instruction. I did it, and all it's ok.:thumbsup:
Matteo
LFCRules
Apologies if this sounds silly, but others inclusing myself have done it. When you have your hand on the volume button, is your hand blocking the infra-red sensor on the front of the panel?? :)
hornydragon
okkraj said:
Instructions tells that "Keep volume (-) button pressed On the panel front and then press status-button on the remote control (button with screen icon and "+"-sign inside the screen)3 times and service menu appears. Nothing happens in my display if I do this? Volume has been 0 - between - full when I have started the pressing of status-button (3 separate tries). In my remote control the status-button is above the setup-button as in instructions.
its the volume button on the screen (not the vol - on the remote you hold)
O
okkraj
I had to check the instructions again and here it is "Hold down the VOLUME (-) button ON THE PLASMA DISPLAY". That's what you get when reading non native language without thinking:oops:.
STUPID ME:suicide: :suicide: :suicide:.
32 hours to go, I quess that I have to start reading calibrating topics more carafully.
