Panny TH-42PHD6 Availability
Discussion in 'Plasma TVs Forum' started by kblue, Aug 20, 2003.
  1. kblue
    kblue
    Sorry if this has already been discussed, but couldn't find any threads by searching!
    Does anyone know when the hi-def 6 series Panny 42" Plasmas will be available in the UK? I can't get a concrete date out of any dealers!
    Thanks for any info!
    KBlue
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Around October, I believe.
    Steve
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,213
    The Borders
    +2,931
    Kblue
    Panasonic in the UK will have limited availability from Mid September - very low numbers to start with (and please remember this is not a 'Consumer' product and will have limited availability through the AV dealer network).
    I know I have one or two confirmed orders and I guess a few of the AV Dealers will also have orders to fulfil so getting one is gong to be pretty tricky for the first couple of months.
    Best regards
    Joe
  4. steve36
    steve36
    Dec 11, 2002
    957
    Warwickshire
    +33
    Joe,
    I assume that as this is not a 'consumer' product it will be only available in wheelie-bin grey.
    Oh well, maybe I could use masking tape and a spray can of car paint !
    Thanks for the info,
    Steve
  5. oreoboy13
    oreoboy13
    Anybody know where i could get hold of the spec list for this?
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,213
    The Borders
    +2,931
    Steve36
    Yes available in any colour as long as its Charcoal grey - though we do supply 'slip over' painted bezels in Silver, Black, White or bare and you paint it yourself.
    oreboy - I should have a PDF in the next day or so.
    Joe
    PS Cost for the slip over bezel is around £350.
  7. kblue
    kblue
    Thanks for your help everyone!
  8. steve36
    steve36
    Dec 11, 2002
    957
    Warwickshire
    +33
    Joe,
    I have to ask, will the slip-over bezel not look a little odd over the top of the existing one ?
    I look forward to the specs on this, if the contrast is similar to the series-5 HD, I may have to reconsider as nothing looks as colourful and bright as the series-6 SD panasonic.
    Thanks again,
    Steve.
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,213
    The Borders
    +2,931
    steve36
    The slip over bezels are 3mm laser cut steel with a high quality baked on paint finish and look excellent. Drop me a note and I can forward you an image or two.
    I must admit I was sceptical but we've now supplied a couple of these and so far they've had the thumbs up (even from those who dictated the displays had to be Silver - you'll know WHO I mean!!!).
    The slip over bezels have cut outs around any logos and buttons and dont have any detrimental affect on your display warranty; they can be installed and removed in about ten second flat.
    Best regards
    Joe
