Quantcast
Panny terminal boards
G
grayson
Where is the best place to buy a panny 6 dvi terminal board, Ive tried Nexnix but they said it would be over a week
symanski
I guess we're all used to next day delivery! Most plasma specialists should be able to get this quickly for you.
All the best,
John.
Joe Fernand
AVForums Sponsor
Hi John
Tomorrows starting to sound too slow!!! if Grayson's in a big hurry and overnights not quick enough he can come and collect :)
Joe
Matthew J Taylo
Grayson,
I'm not too sure I'd bother, the picture via a HDMI to DVI feed from the Pio 868avi isn't as good as my component picture via the Beldon 7710a monster.
I think I need to calibrate my system but with most R1 disc's I've spun (Band of brothers, Jaws) I've found the component picture to be better. T2 was better as DVI.
Your not supposed to see a Pal (R2) picture via HDMI to DVI but I am for most R2 disc's? PQ still not very good though.
Matt:beer:
G
grayson
Got the board thanks to Joe, hooked up my pc to my panny and the picture is absolutely stunning looked close up to see if i could see any fault at all with the pic and nothing, no blemish no grain, picture is razor sharp. Very happy
buns
How are you running it all? Im aware of the issues with the dvi input and keen to hear of anyone who might have got around them....
all the best
ad
G
grayson
I have connected the plasmas dvi to my geforcefx 5600 and i am running it on Powerdvd 5, Ive only watched gladiator, my component feed looks muddy in comparison.
I asked my two sons who are 5 and 9 which one was best and they said dvi
Joe Fernand
AVForums Sponsor
Excellent
Future customer training is underway already - multi room Home Theatre with Plasma and Laser Projection by the age of 15 sounds on the cards then.
Joe
buns
I dont know how you confirm your mapping with the pc..... you'd need to check the pc forum. There is a patern which will confirm but I dont know where you would get it.
I assumed you were running powerstrip on your pc to give a custom timing..... if not I guess this means you are running at 60Hz.
all the best
ad
G
grayson
Just rented Anger management which is a rental dvd and it wont play on my dvdrom drive just keeps spinning and making a clicking sound, it plays fine on my dvd player, any ideas
jrpavel
How did you manage this? When I put a PAL disk into the 868 I just get a colourful noisy mess; no picture, even with the 868 set to NTSC instead of AUTO. (The Panny DVI board only accepts NTSC signals, if I have understood correctly.) I have tried setting the HDMI output to progressive and interlaced at various resolutions, without success.
Similar threads
Trending threads
