Panny Terminal board
boogie man
Right hope someone can help as my brain is well confused:confused:
just about to order TH42PW5B with terminal board (TY42TM4Y) how do i connected sony dvp-s7700 dvd player which has scart rgb out & component out rca phono.
1)Do i go scart rgb to component - SYNCBLASTER CABLE SCART TO 5 BNC 3.0m or SCART TO 3 BNC RGsB to the plasma
or
2)Do i go component 3 rca phono to component 3 bnc to the plasma
just add more :confused: sky + box is connected (rgb) to dvd and outputing rgb via dvd player to the plasma which is best ..:rolleyes:
many thanks boogie man
boogie man
just to add one more thing
would say for sky+ box to plasma not via dvd player
SYNCBLASTER CABLE SCART TO 15 PIN HD SVGA work
via the vga input
please anyone:eek:
boogie man
Joe Fernand
AVForums Sponsor
Boogie man
Two quick questions:
01. Does your Sony DVD player offer Progressive Scan on the Component video outs?
02. Do you have an AV amp in the system that has Component video switching?
Best regards
Joe
boogie man
hi Joe
Just read the whole manual phew !! unable to find anything about saying Progressive Scan on the Component video outs?:eek:
1)not to sure the Component out do (Y,Cb,/B-Y,Cr/R-Y) thats what it says in the manual ?? so for Progressive Scan not sure
2)I have a DENON AVC A1SE which can do Component video switching
thanks Boogie man
thanks for the reply joe
saggio
SYNCBLASTER CABLE SCART TO 15 PIN HD SVGA work via the vga input
With reference to the above solution from boogie man, is it equal or worst than the following?:
RGB SCART out -> SCART2SCART cable (short) -> JS "RGB2PLASMA" box -> VGA cable -> PC input into TV
and if you use the "Syncblaster2SVGA" as above, how do you exctact your Audio signal (to be sent to the AV amplifier instead of the Plasma?
thanks
boogie man
hi saggio
on the sky+ box you have a digital output which is connected to the av amp for Audio ,The plasma is just going to be a monitor no sound for there at all.
thanks boogie man
saggio
thank you Bogie Man,
but I forgot to mention that I do not have a Sky+ box, but a Pace Telewest instead. So no separate Audio output. I have to break it out from the SCART...
Is this Syncblaster from Keene any better tan the JS technology box?
thanks.
jont
Dr. John's RGB boxes do have a pair of phono sockets to break out the audio from the connected scart lead ...
As for what's better do a search on the forum and you'll find a variety of user's views ... "you pay's your money, etc ..."
Similar threads
