Panny Tallboy question
Discussion in 'Home Cinema Speakers' started by Supersonic72, Feb 24, 2005.
  1. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    Hiya guys!
    Some of you may recognise the link below as being a set of Panasonic tallboy speakers, but in your learned experience, theyre described as being part of the X-45 set/range?
    Have done a search, and find no reference to this model/range identity, so what do you make of it all?
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=14996&item=5754311245&rd=1
    Secondly, with just 4 speakers and a sub, how does one get the surround effect with just 5 in total?
    ...or am i being nooby and thick?
    Thanks!
    Steve
  2. Astaroth
    Astaroth
    Jun 22, 2004
    3,708
    London
    +898
    if you read the Q&As they seller says there is a centre speaker too. However most AVRs can create a 'ghost' centre channel if a centre isnt actually there but my limited experience is that you lose a lot of the effictiveness of a system by being forced to do this.
    I cannot comment on the quality of the item so will leave that to others
