Panny skybox crashing (HELP)
Discussion in 'Sky Digital TV Forum' started by Dave H, Aug 31, 2001.
  1. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    help my panny box keeps crashing and most of the channels are not working ,it keeps saying no saterlite signal is being received but if I flik around about a third of the channels are working.<br />I have checked in the services and the signal is strong and the quality is good?<br />I have tried to reset it by turning it off and then holding down the back up button but to no avale it reloads the software but it sometimes works and sometimes doesn't.<br />HELP Dave.<br /> <img src="confused.gif" border="0">
  2. celticprince
    celticprince
    I am having similar probs with my silver Pannie, since the BB9* EPG software download. This download was supposed to be the 'patch' to fix the previous BB5* software, which ironically, worked fine with my box. I have again contacted Sky STS department(second tier support), who are aware of the extended problems. I have been asked to let them investigate, and await further info. I would alert this department to your problems and keep a record of the people you speak to, as this will add to your claim in the future.
