Panny Series 4 - Time Used?
Discussion in 'Plasma TVs' started by Cabo 5150, Jul 8, 2003.
  1. Cabo 5150
    Cabo 5150
    Nov 21, 2002
    103
    +3
    I'm fairly certain Panny Series 4's have some kind of clock or counter establishing how many hours of usage the set has notched up. Anybody know how to access the said information? Ta very muchly...
  2. Glauco BruZZi
    Glauco BruZZi
    Hold down the - volume button on the display while it is on and press the status button
    (The one under the power button) 3 times on the remote control.
    The CAT (Computer Aided Test) menu will appear. Using the Down buttom on the remote go to SD mode and press action (center button) to access the menu.
    On MTBF (Mean Time Between Failure) PT is the total time. the WT might be wait time (standby) but I'm not sure. To exit this menu press the return buttom (r) and then the action button.
    NOTE: If you press the status buttom twice again the CAT menu will still appear. The only way to reset it is to turn the plasma off (remote control or Plasma on/off switch)
  3. Glauco BruZZi
    Glauco BruZZi
  4. Cabo 5150
    Cabo 5150
    Nov 21, 2002
    103
    +3
