panny scht900 tv sound input??
Discussion in 'Home Cinema Buying & Building' started by daviedee, Nov 29, 2003.
  1. daviedee
    daviedee
    hi all.. my tv and panny have been united together, the problem is on the sound output of the tosh 32zd26p into the panny all i can get is 2 channels.
    ive got my ntl box via scart into the tele then sound output to the panny, surely the panny will decode it into 5.1..??
  2. poinsy
    poinsy
    I maybe stating the obvious here, but I assume you have selected the Dolby Pro-Logic II button (down towards the bottom right of the remote) to select the appropriate effect ? This will then convert the stereo signal into 5.1. Like I say, I am probably stating the obvious here.
    Paul
