Panny SCHT520 Question
Discussion in 'Home Cinema Buying & Building' started by hasanhadi, Jan 19, 2005.
  1. hasanhadi
    hasanhadi
    Jan 1, 2005
    62
    hi all.
    does this have an optical input, as everywhere ive checked says that it doesnt.
    how would i connect an xbox to it if it doesnt have an optical input?
  2. blackfly
    blackfly
    I have the same problem, my Dads system though, I want to connect my xBox to his SC-HT520 and HDTV projector (120" screen) but no S/PDIF inputs at all.
    I have an idea that it may be "possible" to jump onto the right pin on the cable that connect the sub woofer to the player. I suspect the actual dolby digital decoder is in the sub woofer, with the proprietary connector including an S/PDIF coax on one of the pins.
    Of course, even if this was correct, we would need to buy a device to convert optical to coax S/PDIF (I recal a device called the CO2 many years ago, but expensive).
