panny saxr45
Discussion in 'AV Receivers & Amplifiers' started by pinky3003, May 18, 2004.
  1. pinky3003
    pinky3003
    Jul 24, 2003
    221
    hi chaps...im looking for some thoughts...my panny xr45 has been in the repair shop for over 6 weeks now....it looks as though i will be getting a new one as spares dont seem to be comming....should i go for another xr45, or see if i could get a xr50...as with some the 45 is not stocked and the 50 is the new kid on the block.....or should i plump for something else as i have room after new stand.....many thanks pinky
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    How much would you be looking to spend to replace the 45?? Does it have to be a half hight reciever or would you be interested in a full height unit? There are a few good amps in the sub £300 and also Denon and Yamaha have released half height amps now.
  3. pinky3003
    pinky3003
    Jul 24, 2003
    221
    its not a question of money....its under guarantee.....i should think they will replace it with another 45....but is it worth me trying to get a 50 ???
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Truthfully I havent heard either. It might be a good idea to look at the 45 and 50's speks and listen to the 50 to see if its worth upgrading.
