Panny S97, pic freezing, Multi region
Discussion in 'Blu-ray & DVD Players & Recorders' started by Delboy, Feb 2, 2005.
  1. Delboy
    Delboy
    Hi all
    Ok, ive got a Panny S97, with picture freezing on some discs. It seems to freeze for about 2 secs, then carry on playing fine, and only on certain dvds. This player has been Multi regioned, but wondering if anyone else has this problem?
    Thks in advance...
    Del
  2. edinburgh160
    edinburgh160
    Hi, I don't get this, but would it possibly be a bad layer transition (midway through the movie) ?
  3. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    Is it a single event - happens once per DVD - which would indicate slow layer change.
    Or is it a repetitive event - happens several times per DVD - which would indicate a problem with DVD or player.
    Do the DVDs in question have special features like seemless branching?
  4. Delboy
    Delboy
    Ok, thks for the replys,
    It happens on the same film, once in the same place, ie, does it on nemo, chpter 15, happened on the punisher @ the week end, rented, and once on shrek or shrek 2, cant remember where on them, checked in other player i have and seems to be no problems on them..yet some films are fine...
    Del
  5. edinburgh160
    edinburgh160
    unusual, but Nemo has 32 chapters, so it looks like its a layer transition.
    I can notice the transition on mine, but it's very slight, and to anyone who doesn't know it wouldn't be noticed.
