Panny S-75 problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by agneepath, Apr 18, 2005.
  1. agneepath
    agneepath
    Dec 27, 2004
    341
    +35
    My pansonic s-75 does not respond to my remote control anymore... not sure why. I orginally though the Remote had died... tried a replacemt RC with no luck.
    The player still works fine but uses of the RC were essential.
    Any ideas or is it time to buy a new dvd player?
  2. Ged
    Ged
    Apr 29, 2002
    922
    +17
    As far as I can remember, there is a way of setting the remote/dvd player to accomodate a DVD-R within the system.
    This means you set up the dvd as 1 and the dvd-r as 2, or vice versa, check the handbook, I know I did something similar to stop them both responding to the same command.
