Panny remotes lost ,em
Discussion in 'Home Cinema Control & Remote Controls' started by jerry, Mar 12, 2003.
  1. jerry
    jerry
    Jan 6, 2002
    421
    london
    +18
    My M in Law has lost 2 panasonic remotes the TV and Video.If I get her an Argos £12.99 jobby will it do the trick and not be too complicated?
  2. nathan_silly
    nathan_silly
    Get a divorce!- then she won't need to come round again and loose em!:rotfl:
    I've found the standard cheapo remotes to loose alot of the features, esp things like videoplus etc.
    Make sure the remote has up, down, left, right and select - otherwise might not be able to navigate the TV and Video menus.
  3. jerry
    jerry
    Jan 6, 2002
    421
    london
    +18
    Cheers Nathan, How much do i have to spend to get videoplus. I am going to try ground up glass!
  4. nathan_silly
    nathan_silly
    If you can afford it, checkout the Pronto at Richer Sounds £99. It will have built-in codes. Also you can download learnt codes from other users (maybe a bloke with the same TV & VCR for any special codes)
    Other than that, Argos have a refund policy, so get a cheap one, use for a week- and if no good return and upgrade to the next one up.
