Panny PWD7 in High Def?
Discussion in 'Plasma TVs Forum' started by JetJockey, Nov 11, 2004.
  1. JetJockey
    JetJockey
    Anybody got any Idea when the PWD7 is becoming available? Also, will it be available in a HD model?
    Thanks, Gerald. :)
  2. Todda
    Todda
    The HD model is called the PHD7 and should be availabvle by the end of the month.
    Although the PWD7 is an SD model it will accept a HD signal. It is apparently not available until January.
  3. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    So will the Panasonic TH-42PW7B Plasma also except a HD signal?I brought a hi-def x-box kit to use with this plama,not to sure i have done the right thing now? :confused: X-box is chipped.
  4. Todda
    Todda
    The PW7 will accept an HD signal so the Xbox picture on your plasma will deffinetely be improved by the kit you bought.
  5. Cheekster
    Cheekster
    Mar 10, 2002
    957
    28
    Oxfordshire
    +32
    What, if any, difference is there between a plasma panel being High Definition and one that is Standard Definition but will accept a High Definition signal?
    Thanks.
    Cheekster.
  6. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    The PW7 has a resolution of 852x480 and the HD model has a res of 1024x768
  7. JetJockey
    JetJockey
    Hi.
    Thanks Todda.
    How come the High Def PHD7 is becoming available before the Standard Def model? :confused:
    Will the High Def PHD7 have all of the new generation bits touted for the PWD7 (newer panel, longer life, low burn, increased shades and colours)?
    Thanks, Gerald. :)
    P.S. And will it fit/mount on the existing PWD5 Wallplate?
  8. Todda
    Todda
    It has got all the new features that the PW7 has.
    I don't know why the PHD7 is being released first. I had thought the PWD7 was being released very soon until I read a post from Joe Fernand a few days ago.
  9. Repo
    Repo
    Jul 21, 2004
    430
    Sheffield, UK.
    +21
    That's a US XBox then? I thought all UK XBoxes had the HD circuitry disabled?
  10. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Repo my x-box is chipped and when set at NTSC will except HD signals.
