Panny PWD6 and X Box
Discussion in 'Plasma TVs Forum' started by novicegeek, Jul 5, 2005.
  1. novicegeek
    novicegeek
    Hi guys, just got an xbox yesterday but need some help connecting it to my Panny PWD6.
    My current setup is as follows :
    1) SKY+ to PWD6 via RGB/VGA converter. Audio is via Bose Lifestyle 8.
    2) DVD (sony LS785 VS) to PWD6 via component. again, audio via Lifestyle.
    How can I fit an x-box into this configuration???
    Help is much appreciated
  2. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    Have you any other connectors on the pwd6?
  3. novicegeek
    novicegeek
    Er no...
    Just the VGA and Component board...
  4. novicegeek
    novicegeek
    The x box comes with standard video leads and a scart converter.
    What I don't get is why it doesn't display a thing when I conected the scart converter into my JS box (RGB to VGA)??
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's because the standard video leads carry composite only, not RGB. Go get an RGB connector from game or summat, connect it to VCR scart on sky, and it will miraculously appear when you turn it on. You may need to connect audio independently, depending on how sky is done at the moment.
  6. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    buy yourself an xbox RGB lead, about £5 on ebay
  7. novicegeek
    novicegeek
    Thanks guys, just getting myself off to ebay. I am sure this question gets asked a lot so I will apologise for my ignorance.
    What about the X2VGA+? Does that work and is it better than normal RGB output??
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It probably does, a bit, but you'll need to figure out how you use the VGA connector. I' didn't suggest this way cos it's already connected, thought you'd prefer to do it the easy way,not to mention cheap. You'll need either a VGA board, or a KVM type VGA switch if you go this route, or else you unplug the VGA lead and swap it. Be warned, VGA plugs are not like mains plugs, they have an intended 'cycle life' built into them, it might only be 50 cycles, ie plugs and unplugs. They tend to break after this, so it's not a good permanent solution.
  9. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    The vigidi (a bit like the x2vga+ - that may come with pass thru as well) comes with a vga pass thru so you can leave them all connected - not sure what affect this would have on PQ from the JS tech. Not sure, but I think you might have to mod you xbox to use the component (which plug into the vga convertor) connections - I'm sure someone will confirm / deny this...
  10. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I learn something every day round here, especially about consoles! Thanks mate.
  11. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    This has confused me (easily done :) ) Is this the VGA cable, Terminal board or something completely different???
  12. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    I would assume a combination of the plug on the cable and the connection on the plasma. Ideally you should leave it a all connected.
  13. vileda
    vileda
    Oct 15, 2004
    401
    Very very confused now :confused: :confused: , I've worked in IT for a while and have never ever heard that VGA cables / Inputs have a lifespan dependent on how many times they're pluggen in etc.
    Flash memory yes (about 1000 times) VGA Connectors no. . .
    If this is the case (and I still can't believe it) it's lucky that the cable is permanantly connected to the display and I just connect my laptop from time to time. :confused:
  14. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Gospel truth mate, and the number of ins and outs is usually about 50-100!! And that will go for the socket too, they are just not built to be played with. Those tiny little pins don't stand up to abuse. Of course it doesn't mean that yours will fail on the 51st plug, just means it's not designed for it.
  15. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    better safe than sorry with expensive bit's of kit...
  16. vileda
    vileda
    Oct 15, 2004
    401
    Ahh so the pins on the cable, that would make some sense, although i've never heard that before.
    At least a new cable is only £4 rather than a new terminal board @ £70ish, unless the pin breaks in the board, ouch.
  17. vileda
    vileda
    Oct 15, 2004
    401
    Cont........
    Not that I'm going to be touching the cable much. It was just that I've never heard this before, bit of a design flaw on laptops then!!!
