Panny PW7 Problems could be me any Help greatly appreciated
Discussion in 'Plasma TVs' started by Dicky pw7, Mar 10, 2005.
  1. Dicky pw7
    Dicky pw7
    Recently bought PW7 with scart board. Have connected video, xbox, ps2, and phillips freeveiw box through "all for one" scart box (not cheapest worked well with TV.
    Everything is fine apart from the freeview which is unacceptably bright, skin textures are as though on maximum contrast and I can't seem to fix it, (tint option on menu won't work on freeview picture either).
    Normaly I'm not bad with this sort of thing so I must be missing something
    Any siggestions??? :lease:
    Dicky
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    Is it the same with a direct connection to the plasma?
  3. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    do you mean the PW7 menu or the freeview menu?
    cheers,tam
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    is freeveiw outputting RGB or composite???
  5. Dicky pw7
    Dicky pw7
    The PW7 menu
  6. Dicky pw7
    Dicky pw7
    RGB
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    some STB's (never used philips) have an internal brightnes/contrast control check for one of those........ and what is your reception like good and strong or does it go blocky and break up often?
  8. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Dicky,
    You've bought a good plasma panel and the Freeview picture should be good. The scart board wouldn't have been my choice but it isn't that bad - I am suspicious of your "all for one", I suspect that is where the problem lies.
  9. Dicky pw7
    Dicky pw7
    Deep Joy :clap:
    That's done it, picture seems to be perfect, obviously I need to play about / get a different scart splitter. It seemed to be a good one :oops:
    Can anyone recommend a "splitter" or media box? :confused:
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    QUINTRO £70ish or perhaps the Joytech one from play £40ish or £60 for the new one
  11. Dicky pw7
    Dicky pw7
    I'm busy making adjustments and reading the instructions again.....
    ....and again :suicide:
  12. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Dicky,
    Good to hear that things are improved. Quintro may not be necessary, a J S Tech Master Scart Controller may do the trick, though it all depends on your games consoles and the type of output that they are configured for. More info needed to give more help - PS2 outputting?, X box outputting?
  13. Dicky pw7
    Dicky pw7
    PS2 is on scart (nothing special shop bought with plug for gun and separate audio cables, but I use optical to DVD/surround which is superb) must admit only tried Battlefront and was a little disappointed with picture, wanted to play about with settings , but time is against me, only seem to get a couple of hours to myself before bed.
    X box is on the RGB cables connected to the scart it all came with, seems to be better than ps2 but again need time to play.
    Thanks again for help, any suggestions for better connectors appreciated, there seems to be so much stuff, not all of which "does what is says on the box". :rolleyes:
