Panny PW7 Power Lead
Discussion in 'Plasma TVs Forum' started by rugbyboy14, Jan 18, 2005.
  1. rugbyboy14
    rugbyboy14
    Oct 12, 2004
    56
    Hi all,
    I need to chase the power cable on my Panny PW7 37" into the wall, the cable is not long enough, does anybody know where i can get hold of a longer one?
    Cheers Everybody!!!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    just get some 3 core and an IEC plug from CPC/RScomponents any length you need (simple really)
  3. Member 55145
    Member 55145
    Jan 18, 2005
    12,079
    +3,479
    or buy an extension lead :zonked:
  4. darktherapy
    darktherapy
    I had the same problem. I bought a 5m cable from Maplin.
  5. rugbyboy14
    rugbyboy14
    Oct 12, 2004
    56
    That is exactly waht i need a 5m power cable, Thanks very much? is it in maplins under power cables? :smashin:
