Panny PW7 - Can you remove green tint on VGA
Discussion in 'Plasma TVs Forum' started by rhodos, Nov 15, 2004.
  1. rhodos
    rhodos
    Oct 3, 2004
    1,640
    63
    Wirral
    +151
    Folks - thanks for the advice on helping me to choose a great screen. It really is as good as CRT via JS RGB to VGA or even the old Scart board :)
    However one niggle - I cant get rid of the green tint thru VGA. I can on scart as I can change colour and hue but you can't do that on VGA.
    Would a 'professional' have access to other options to adjust this? Its not major but people look sick at times :) and white walls aren't they are white with a green tint.
    I'm considering selling the JS converter and just using the Scart coz its really beginning to bug me. Is there anything that can be done?
    I tend to use auto mode with contract on 10, brightness on 3 and sharpness on 0. Settings tend not to affect it though. Still green.
    Sorry if its a repeat post - I have searched and found you can't change colour normally thru VGA but I just throught there must be some way as people can't surely pay £2K and watch green faces all night?????
    I stress its only a slight tint - but again for the price I wouldn't expect it.
  2. njr
    njr
    Aug 23, 2002
    115
    16
    Berkshire
    Try these settings and see what you think. I reckon these settings have removed the green tint on my PW6.
    Normal setting
    Contrast -13
    brightness 0
    sharpness 4
    colour temp normal
    advance settings on
    black extension n/a
    Input level -12
    WB high red -5
    WB high blue 9
    WB LR 12
    WB LB 12
    gamma 2.2
    AGC off
  3. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    There's no tint control as such on the VGA input, I find it does really need one as it's such a raw and direct input. However, you do have gamma control and also the ability to adjust the white balance for high Red and Blue in the advanced settings. Also, try changing the Picture Mode setting as it seems to have a general affect on the picture.
    Also, please check the settings on the source equipment.
    All the best,
    Dr John Sim.
  4. rhodos
    rhodos
    Oct 3, 2004
    1,640
    63
    Wirral
    +151
    Thanks all - a move towards njr's settings has helped. To stress it really is minimal and on anything sub-£1000 i wouldn't have even mentioned it.
    Am I right to assume though that the Scart input required much more red tint adding to avoid the green tint because it is not as pure as the VGA input - i.e. the level of green tint is not equal across all inputs for the same settings?
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,037
    Panasonic plasma's load up hidden service menu settings based on incoming signal type and format. ie send them a component 480i signal and a SCART RGBcvS 576i signal and they will load up different sets of settings in background that you cannot see. The User settings are global offsets applied to these hidden settings.
    in order to make each source and input correct you need to get in to the service part and make adjustments so that the user menu offsets are not required for anything except sharpness. These service settings are probably set up on a prodcution line with test pattern generators in an automated procedure. However the varience in output levels between DVD players, STB's etc from different manufacturers and within a manufacturers product line means that there is going to be a requirement for tweaking.
    Hope this is a little use.
    Gordon
