Panny PW7 auto widescreen sensing
Discussion in 'Plasma TVs' started by Nick_T, Nov 26, 2004.
  1. Nick_T
    Nick_T
    Nov 3, 2004
    114
    16
    Cambridge
    Im looking at getting the Panasonic TH-42PW7B with the component video board rather than SCART and converting the SKY+ signal through a new Panasonic DMR-E55 DVD Recorder.
    I have been told that without the SCART terminal board I will loose the Plasma's auto widescreen sensing to automatically detect the aspect ratio.
    Question is, will this matter? Surely not if the SKY+ and E55 boxes are both set to 16:9 and the plasma is set to 16:9 there will be no need for auto switching?
    Just wanted to make sure what this meant! Cheers :thumbsup:
  2. stevelup
    stevelup
    Aug 13, 2002
    6,132
    Swindon
    +843
    You will need to toggle every time the broadcaster switches between 16:9 and 4:3 otherwise you will end up with a stretched picture.
    Sky doesn't permanently output a 16:9 image - it only does so if that particular broadcast is being transmitted in anamorphic 16:9.
    There is a gadget available which connects to the serial port of your Plasma and performs the switching. I think it's about £90
    It's on sale here in either the powerbuy forum or the special offers forum - I can't remember which.
    Steve
  3. Nick_T
    Nick_T
    Nov 3, 2004
    114
    16
    Cambridge
    Cheers for that. I currently have a failry new widescreen Panasonic CRT TV, I'm sure when Sky displays in 4:3 it just stretches the picture anyway (I have the TV set to 16:9, but even in the Panasonic auto setting it does the same, just stretches the edges more than the middle)!? So what would the plasma display if the Sky+ was plugged in to the SCART Terminal board? Would it become 4:3 and display balck likes at the left and right?
  4. stevelup
    stevelup
    Aug 13, 2002
    6,132
    Swindon
    +843
    It's your TV doing the stretching - not the sky box. The sky box always outputs either 4:3 full frame or 16:9 anamorphic. It doesn't do any manipulation to the image.
    (The exception to this is if you have letterbox mode enabled - the box squashes the anamorphic 16:9 stuff and sticks black bars on the top and bottom)
    You can configure how the panel treats an autoswitched 4:3 image - either 4:3 (with black bars) or Just mode (which just stretches the edges).
    Regards,
    Steve
