panny pw6
Discussion in 'Plasma TVs Forum' started by fitz62, Mar 13, 2005.
  1. fitz62
    fitz62
    have i got this right ? followed this forums advice ,i was on the verge of buying a tiny plasma and thankfully stumbled across this forum and made a swift u turn ,cancelled the tiny and bought the pw6.everything is fine the pic is fine even on terestrial tv,no buzzing or probs, but have i got it right?.i got a daewoo box with the package and a dvd recorder,ive put the rgb into the dvd recorder not the daewoo ,which i was told to do when i put it in there i cannot get a pic,so my signal comes from the dvd recorder and scart to scart sky ,the daewoo box is really unused apart from connecting the pw6 to sky and dvd ,is this right?. anyway thanks for really good advice :lesson: made up with the panny ,just waiting for my refund (deposit) from tiny,who actually delivered their plasma 8 days after i cancelled it :thumbsdow
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    ditch the Daewoo crap tuner (dont need it, assume you bought from RS) depending on the DVDR you may just need a cable!!!
  3. fitz62
    fitz62
    i have no connections on the rear of my pw6 ,whats the best option from here? you're right i bought the package from rs,but cant fathom what the daewoo is doing,still happy with the deal,but if it can be better!
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    you can do component to vga on the pw6
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    or buy a scart board or JS RGB>VGA converter
  6. fitz62
    fitz62
    this is all technical stuff, i set the whole shooting match up mtself and was well pleased just to get a picture,not the sharpest tool in the box when it comes to this ,dum it down a little,who can help me i can't see myself going into currys and getting any sense out of them :D
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    does your dvdr have component out?...red green blue..3 rca sockets?...if so you can buy a cable with the three rca terminaters on one end and a vga on the other...vga being the pc input on teh screen...look at the vga to 3 rca on the link here http://www.av-sales.co.uk/html/vandamme.html then you can do sky to dvdr and dvdr to screen using teh cable
  8. fitz62
    fitz62
    think ive got that,and that will give me a better pic than my current set up?
  9. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    will be better than scart
  10. jwillans
    jwillans
    MEP: Is this also the case for the PWD6BX?
    James
  11. gstadt
    gstadt
    Sep 22, 2004
    289
    28
    Cardiff
    +25
    It is - I have one
    Gstadt
